Activity Forums VEGAS Pro Problems with audio in VEGAS Pro
  • Problems with audio in VEGAS Pro
    Posted by Heloísa Maia on September 4, 2026 at 10:28 am
    Why does my audio sometimes go out of sync with the video in VEGAS Pro? It starts perfectly synced when I’m editing but after adding cuts and effects the audio can slowly become delayed. How can i fix this?
    Silviu Negoita
    replied 2 weeks, 6 days ago
    2 Members · 1 Reply
  • Silviu Negoita
    September 4, 2026 at 11:23 am
    This can sometimes happen if the audio and video have different frame rates or if the source uses variable frame rate footage. I’d first check that your project settings match your video, and if the issue continues, try converting the footage to a constant frame rate before importing it into VEGAS.This video may also help with fixing audio sync issues: https://www.youtube.com/results?search_query=VEGAS+Pro+audio+out+of+sync+fix
