Activity › Forums › Adobe Premiere Pro › Problems with AE Overlay Opacities Since Update?
  • Problems with AE Overlay Opacities Since Update?
    Posted by Brent Taylor on April 22, 2015 at 9:39 pm
    Is anybody else having this problem?
    Ever since I got on Pro CC 2014, I’m having issues with overlaying graphics onto footage. When I do an overlay in AE the opacities are kind of messed up.
    For example, I’ve been working on some footage that includes a solid color box at about 90% opacity over footage of someone speaking in front of a white background. Ever since the update, the box looks significantly more darker (and more correct) if I put all the footage in After Effects than it does if I bring link just the overlay and put it over my footage in Premiere via Dynamic Link. This slows me down quite a bit and is a real pain if I need an overlay to span across multiple cuts in Premiere.
    It only started doing this since the latest major update. I held off for a long time trying to avoid it but sooner or later I needed to get current. I just tried it in Premiere Pro CC to confirm, and yup… no problem.
    Any ideas?
    Brent Taylor replied 11 years, 5 months ago 1 Member · 2 Replies
  • Brent Taylor
    April 22, 2015 at 10:37 pm
    Here are examples of what it’s doing. These are taken from final renders.
    Object Overlay:
    Text Overlay:
  • Brent Taylor
    April 22, 2015 at 11:07 pm
    So I showed my post to Adobe Support and they seem to have solved it pretty quickly. I gotta say, Adobe Support is pretty good.
    Here is a transcript of the relevant parts for anyone else who stumbles into this. The solution is in bold.
    Adobe: which graphic card is installed on the computer?
    Me: an AMD Radeo HD6450
    Me: *Radeon
    Adobe: in premier pro ,please go to file< project settings< general
    Adobe: please change the render to mercury playback engine software only
    Me: ok
    Adobe: have you chnaged it?
    Me: Yes I did
    Me: now please try to edit it again and check it
    Me: I think that fixed it
    Adobe: great
    Adobe: it was the type of render
    Me: is there anything else that i can do for you?
    Me: No, I think that will do it. Thank you!
