Activity Forums Adobe Illustrator Problems Using the Clipping Mask function
  • Problems Using the Clipping Mask function
    Posted by Wayne Sykes on November 27, 2010 at 11:53 am
    Hi Newbie here,
    I’ve looked at several youtube videos on how to use the clipping mask feature in Illustrator and maybe it’s just me, but I still can’t get my head around making it do what I would like it to.
    I would easily be able to do this in Photoshop by highlight the text, then selecting the layer I wanted to delete from and simply hitting delete, but this clipping mask is stumping me.
    Basically I would like to delete the word “CLOTHING” from the long sections of the 2 K’s then replace the word “CLOTHING” slightly smaller so that you can see through the 2 K’s…
    Hope somebody can help me..
    Wayne
    1327_logo.ai.zip
    Wayne Sykes replied 15 years, 6 months ago 2 Members · 3 Replies
  • Vincent Rosati
    November 27, 2010 at 5:45 pm
    Hello Wayne,
    I’m sure there are a dozen approaches to doing this, but if I’m reading you correctly this is what I would do…
    Pathfinder: Minus Back logob.ai.zip
    1
    Object/Expand Everything.
    2
    Ungroup Everything.
    Select the K’s and Object/Compound Path/Make.
    Group all of the whites, then Copy/Paste in Back, then Object/Arrange/Send to Back.
    With the ‘Back’ whites still selected, shift-select the compound path K’s and Pathfinder/Minus Back
    3
    Pretty much, repeat step 2…
    Select the black letters and Compound Path/Make.
    Select the white compound path and Send to Back.
    With the whites selected, shift-select the black letters and Pathfinder/Minus back.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Wayne Sykes
    November 28, 2010 at 3:35 pm
    Hi Vincent,
    Thanks for getting back to me…
    This seems to be working to an extent. The only problem I seem to be having is when I use the Minus Back function, is extracts only the original shape of the letters excluding the stroke.
    I really need to have the stroke included, so that when I overlay the original lettering there is the transparent space between the K’s and the CLOTHING.
  • Wayne Sykes
    December 3, 2010 at 11:15 pm
    Just had to expand the text with the stroke twice and then follow the steps…
