Activity Forums Apple Final Cut Pro Problems using HDMI to monitor playback from fcp x
  • Problems using HDMI to monitor playback from fcp x
    Posted by Robert Castiglione on April 1, 2014 at 11:23 am
    Hi
    I am having difficulties monitoring playback back in fcp x out of a new Mac Pro via HDMI.
    I have a Panasonic Plasma TV hooked up via HDMI. The television shows up and is identified as a secondary monitor in the system preferences.
    However, it does not show up at all in FCP X in the preferences. It simply says AV “None Found”. Under the windows pane AV is greyed out. I am on the latest version of FCP X and latest version of the OS.
    Any thoughts?
    Rob Castiglione
    Bret Williams replied 12 years, 5 months ago 2 Members · 5 Replies
  • Robert Castiglione
    April 1, 2014 at 1:21 pm
    Strike that.
    I have sorted it out. Very straight forward – the project must be in a format recognised by the Panasonic eg 1080P. That was it. If they are not the TV wont recognise the HDMI signal and FCP X will tell you that there is no AV device attached.
  • Bret Williams
    April 1, 2014 at 8:00 pm
    You just gave me new hope for my 5770 card with hdmi out. I have it installed on a MacPro 1,1 jury rigged to run mavericks and FCP 10.1.1. The other day I pulled up the prefs to see if the HDMI was a viable out like on the MacPro, but nope. But I didn’t have a monitor hooked up.
  • Bret Williams
    April 2, 2014 at 11:02 pm
    It worked!
    April 2, 2014 at 11:03 pm
    Excellent news – glad that the information was useful to someone! Best Rob
  • Bret Williams
    April 2, 2014 at 11:05 pm
    I found if you’re mirroring the desktop it also doesn’t work. Have to be in extended desktop mode.
