Activity › Forums › AJA Video Systems › problems using AJA IO with macbook pro
Posted by Marcosh on September 5, 2006 at 2:14 amHi all,
I’m trying to capture from a Digi Beta tape using an AJA IO LD box connected to my MacBook Pro but FCP (5.1) can
Dave Martin replied 20 years ago 3 Members · 4 Replies -
Marcosh
September 5, 2006 at 8:55 pmJeremy,
The driver update may have done it. I updated from 1.2 to 3.0 and it seems I’m getting the signal through it. I’ll be able to connect it to a deck tomorrow when I’ll know for sure.
Marcos H.
Quad G5
2GB RAM
OS 10.4.7
FCP 5.0.4
AE 6.5 -
Jeremy Garchow
September 5, 2006 at 9:02 pmYep, that will do it. V3.0 is universal which is what you needed to use with your MBPro. V1.2 is PowerPC only and is probably what came on your install CD.
Hope it works with your deck tomorrow (it should). If you have any other problems post back.
Jeremy
Dave Martin
September 20, 2006 at 11:29 amDid you find and ExpressCard 34 firewire 800 card to use with the MacBook pro?
Tim Martin
-MacBook Pro – 2.16GHz Intel Core Duo – 2 gig Ram
-FCP Studio 5.1.1 – QT 7.1 – OSX 10.4.6 – Lacie D2 dv external drive – G-raid dv drive
