Activity Forums VEGAS Pro Problems running Sony Vegas 12/13 [Technical]
  • Problems running Sony Vegas 12/13 [Technical]
    Posted by Toine Verhoeff on February 25, 2016 at 5:54 pm
    Hi!
    I’d like to start to talk about what i do and what kind of computer i use to do it!
    I work as an editor for YouTubers who play and records Video Games.
    My work consists of mostly cutting work without any significant touch ups on the video (as for effects)
    I use a Desktop computer with the following specs;
    Intel Core i7 3770K (Clocked Default 3.5Ghz)
    16 GB DDR3 RAM
    Samsung EVO 850 256 GB SSD
    Nvidia Geforce MSI 970GT
    Dell 2560×1440 IPS Monitor (Displayport)
    AOC 1920×1080 144 Hz Monitor (DVI-D Port)
    I Use 1 Audio line for a voice compressed .mp3 (usually 15-40 minutes long)
    2 Video Lines for a facecam and gameplay footage. Both compressed M4V’s using somesort of converter in 1080P & 60 Frames per Second (not sure which one my client uses)
    As i make a lot of cuts i notice my CPU taking a big hit and i wont be able to work smoothly.
    I’ve turned down my Video Preview to Preview(auto) and sometimes when it gets really bad i move it down to half or even Quarter.
    It doesn’t really matter what kind of preview setting i’ll use.. i’ll always get about the same framerate lagg on every single one.
    I’m well aware that my GPU gives 0 input or support to this process as the Maxwell chips are NOT supported (i’ve been digging old topics for months)
    Everything i try ends up not working at all and it seems that if i make more cuts.. the more my CPU takes hits.
    What parts should i replace to eliminate all of these problems!
    It doesnt seem like im asking a whole lot from Vegas but im required to use Vegas for this particular client.
    This probably wont show a whole lot of what’s actually going on but.
    https://i.gyazo.com/561bc830ad7554d6836b11ba2fa3ab80.png
    Im desperately seeking help!
    John Rofrano replied 10 years, 5 months ago 3 Members · 14 Replies
  • 14 Replies
  • John Rofrano
    February 26, 2016 at 4:54 am
    A Hex Core instead of a Quad Core would certainly give you a boost as would an AMD R9 290x/390x instead of the useless NVIDIA card.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Toine Verhoeff
    February 26, 2016 at 9:32 am
    As of this month, Priority would be to get a CPU THEN a Graphics Card? or would you recommend getting a graphics card first.
    Also is the 390x supported ?
    Thanks for the quick response!
  • Toine Verhoeff
    February 26, 2016 at 10:21 am
    Although, a 3770k should easily be able to handle some simple cutting work!?
    It’s just giving me 100% CPU Load all the time, now and then it’s completely gone.. so i’ve got no clue what causes it!
  • John Rofrano
    February 26, 2016 at 2:20 pm
    [Toine Verhoeff] “As of this month, Priority would be to get a CPU THEN a Graphics Card? or would you recommend getting a graphics card first.”
    The right graphics card can have a *significant* impact in playback. In the testing that I’ve done in this thread, the difference between GPU on and off was 29.97 fps playback with it on and 0.5 fps with it off. That’s a 60x improvement!!! That was using an ATI Radeon HD 5870.
    The question is whether it will speed up your footage and the answer is, I don’t know. GPU support is hit-n-miss with Vegas Pro. I’m guessing that your CPU is having a hard time decoding the highly compressed MPEG4 video you are feeding it and the GPU would be a tremendous help with that, but unfortunately, you need to try and see.
    What I could do is test for you. If you send me a DropBox link to some footage, or even with a project with a lot of cuts that doesn’t play back smoothly on your computer, I could test it with and without my GPU on my computer and see of the GPU alone makes a difference. The results might be skewed because I have a 12-Core and you have a 4-Core but I can always test and see.
    [Toine Verhoeff] “Also is the 390x supported ?”
    Vegas Pro supports OpenCL so any card that implements OpenCL is supported. The R9 300 series and 200 series are supported.
    ~jr
  • John Rofrano
    February 26, 2016 at 2:24 pm
    [Toine Verhoeff] “Although, a 3770k should easily be able to handle some simple cutting work!?”
    Yea, the problem might be the codec compression used on the files you are editing. Also, the container they are in. Sometimes Vegas Pro can’t edit files easily because of the way they are written. Vegas Pro is tested with “real” camera footage. Then people come along with all these free game capture programs and who knows how the files were written but they certainly are not consistent or always optimized for editing.
    ~jr
  • Toine Verhoeff
    February 26, 2016 at 5:12 pm
    Thank you thus far for all the help!
    I used to do the same work for a different client whom had similar gear but a different camera used as “facecam”.
    I’m almost sure it’s the camera giving the extra load.
    Unfortunately i’m not allowed to share the media i am editing so i’m afraid i’ll just have to check one or another!
    I’ll start with the 390x which should be easier to return rather than a CPU + Motherboard
    Ill keep the topic up to date as soon as i know more!
  • James Hauge
    February 26, 2016 at 7:57 pm
    A thought that I’ve used before was to pre-render my source into a format that’s suitable for editing… as little compression as possible and like 30 mbps throughput…
    That’d be a simple starting point to see if it’s the source files that are causing your problem…
  • Toine Verhoeff
    February 27, 2016 at 8:06 pm
    Hi James!
    As of current i have not tested it with a GPU yet.
    I can playback the entire raw footage without any stutter. It occurs when i have about 200 Cuts or so done to the project.
    I will test out your idea. Havent tried that yet!
    Thanks for thinking with me!
    ~Toine
  • Toine Verhoeff
    March 5, 2016 at 7:49 pm
    Okay Just installed a 390x in my computer and it works like a charm!
    My CPU still makes vegas tilt a bit so i go to my Task Manager and put the Afinity to 5 cores max.
    Now i can watch back my footage on Best(Full) without any stutter.
    It’s obvious i’ll still have to replace my CPU for this matter to make everything run smooth but as of now it’s a great temporary fix!
    Thank you for your input.
    I am now also looking for a Laptop to do the same thing on.
    You’d recommend doing the same thing by getting a AMD M395 + 6820HK ?
    I’ve seen an Alienware laptop carrying these following specs
    Intel® Core™ i7-6820HK (8MB Cache Quadcore 4.14Ghz)
    AMD Radeon™ R9 M395X with 4 GB GDDR5
    15,6 inch UHD IGZO2 IPS-Screen (3.840 x 2.160) Matte coated 300 Nit
    16 GB Dual Channel DDR4 2.133 MHz (8 GB x2)
    It would be either that or a similar Specced DELL XPS 15 Laptop with
    i7 6700HQ Quad-Core, 6 MB cache, 3,5 GHz w/ Turbo Boost
    NVIDIA® GeForce® GTX 960M with 3 GB GDDR5
    Your thoughts on this?
    I’ll be upgrading my CPU to a 5960x which should suffice on my Desktop
  • John Rofrano
    March 6, 2016 at 12:42 pm
    [Toine Verhoeff] “You’d recommend doing the same thing by getting a AMD M395 + 6820HK ?”
    Yes, but understand that a mobile GPU won’t have anywhere near the processing power of a desktop GPU. The AMD M395 has 1/2 the power and bandwidth of the AMD R9 390 desktop version. Not that you shouldn’t get it, just that a laptop will never compare to a desktop in performance.
    [Toine Verhoeff] “I’ve seen an Alienware laptop carrying these following specs”
    I would go with the Alienware. The Dell has an NVIDIA GPU which will not perform as well with Vegas Pro.
    [Toine Verhoeff] “I’ll be upgrading my CPU to a 5960x which should suffice on my Desktop”
    That 8-Core is an excellent choice. That’s what I would be using if I hadn’t switched to a 12-Core Mac Pro. 😉
    ~jr
