Activity Forums VEGAS Pro Problems rendering a video
  • Problems rendering a video
    Posted by Bernardo Fajardo on August 28, 2026 at 3:17 pm
    I’m currently working on a video for my YouTube channel and I’ve noticed an issue with the final quality. The video looks perfectly good when I’m viewing it in the VEGAS preview, but once I render it, the footage looks noticeably more blurry. I’ve tried rendering it again but the same thing happens. Does anyone know what might be causing this or have any suggestions on how to fix it?
    Bernardo Fajardo replied 3 weeks, 5 days ago 2 Members · 2 Replies
  • Silviu Negoita
    August 28, 2026 at 3:21 pm
    Hello! I’d first check the render settings, especially the bitrate and resolution. Make sure the render resolution matches your project/source, and try increasing the bitrate if it’s currently low.
    Also check that the footage isn’t being unnecessarily scaled and that resampling isn’t causing the softness.Hope that helps!
  • Bernardo Fajardo
    August 28, 2026 at 3:38 pm
    Thank you so much, that helped me!
