Activity › Forums › Adobe Audition › Problems Recording
  • Problems Recording
    Posted by 0239666 on August 24, 2005 at 11:35 pm
    i just got Adobe Audition 1.5. I hooked my turntables up to the PC. And when I press record the track that is already laid down plays back but I can’t hear the input from the turntables. It does record the input from the turntables it’s just I can’t hear it through the headphone jack in the PC while recording. How do I fix this?
    0239666 replied 21 years, 1 month ago 2 Members · 2 Replies
  • Willie Toth
    August 25, 2005 at 12:52 am
    Check at the side of the track under IN and OUT and make sure you have the out routed where your headphones are plugged into, also go to the OPTION tab at the top of the screen and then go to DEVICE ORDER and check what it has set up as a playback … Can you hear other audio through the headphones ……. WILLIE
  • 0239666 Create COW Profile Image
    0239666
    August 28, 2005 at 8:52 pm
    Yes I can hear all playback through the headphones but I can Never hear live input. The out is routed properly.
