Activity › Forums › Apple Final Cut Pro Legacy › Problems recording HD to the 1200A
  • Problems recording HD to the 1200A
    Posted by Herb Sevush on August 6, 2005 at 2:14 am
    I’m having a weird problem using the 1200A with FCP5.
    I’m working on a project using varicam footage shot at 720P/60. I’m working in the DVCPROHD codec – I imported the footage via firewire.
    I have some graphics supplied to me by the client on DVCPRO that features sparse animation on a pure white background. I also have a title sequence composed in motion that features a white background. The whites in both cases read just under 100 on the FCP scopes.
    When laying back to the 1200A all the live action video records perfectly, including shots with peaks at about 105. But the white graphics have huge quantization errors and cause servo errors on the deck. It doesn’t matter if I record via firewire or via HD-SDI using the blackmagic codec. The white graphics can’t seem to be recorded by the deck.
    I’ve sent the deck back to Panasonic but they claim there is nothing wrong with the deck. except for some dirt on the heads. While it’s true that cleaning the heads will help reduce the problem, it in no way does away with it. For now I’m reducing the levels on the white to about 85, which is not a choice I would otherwise make.
    I’ve also posted this message on the Varicam forum.
    Anybody seen anything like this or have any suggestions?
    Herb Sevush
    Zebra Productions
    Herb Sevush replied 21 years, 1 month ago 2 Members · 2 Replies
  • Videomansf
    August 6, 2005 at 7:40 pm
    I don’t know, but here is the manual for the deck:
    https://www.zacuto-rentals.com/AJ-HD1200A.pdf
    VM
  • Herb Sevush
    August 7, 2005 at 6:29 pm
    VM –
    Thank you for your response, but I have the manual. And believe me, there is more to say about the 1200A that has been left out of the manual than is in it.
    Herb Sevush
    Herb Sevush
    Zebra Productions
