Activity Forums Apple Final Cut Pro Legacy Problems printing to video
  • Problems printing to video
    Posted by Julie B on July 20, 2006 at 6:39 pm
    I don’t get it. I have the hardest time running my projects off to tape. Almost every time I try, it drops frames (at different, random places in the program). I’m working on a Mac OS X Dual 2.3 GHz PowerPC G5, 2.3 GB RAM, FCP 5.0.4. I’m mastering to a Sony DSR-20 DVCAM deck via firewire. My FCP file is on my internal hard drive, all the media & render files are on an external drive (connected by firewire (400). My RT is set at “safe” and my playback mode is low, playback frame rate is full, record to tape is full quality, realtime audio mixing is set a 4 tracks, audio playback is low. I don’t know if this would affect it, but I’m not using any of the generators in the print to tape box…my bars & tone, slate, countdown, etc. are on the timeline. I’ve tried it using the generators, but no change in dropping frames. This is a laundry list of stuff, but I’m trying to fill you in on what I’m doing and how I’m doing it.
    I’ve done everything the dropped frames dialogue box tells me (except upgrade my computer)…and I still drop frames! It’s too the point that taking something off to tape is a 2 day process Oi! My co-worker often has the same problem. He’s running a similar setup as me.
    Does anyone have any suggestions as to how I can make this process less time consuming/painful? Thanks in advance for your help!!
    Julie
    FCP Studio, After Effects 6.5, PhotoShop 7
    Sgvideo replied 20 years, 1 month ago 7 Members · 26 Replies
  • 26 Replies
  • Jerry Alto
    July 20, 2006 at 7:18 pm
    Julie- This problem has been addressed many times in the forum. The best guess is that it is a firewire issue. The problem being that you are operating two pieces of hardware on the firewire bus at the same time. A quick and inexpensive solution may be to buy and install a PCI firewire card (less than $25) to give your system a 2nd firewire bus. Hope this helps.
    Jerry
    G5 Dual 3GB Ram
    FCP5 Studio
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
  • Thaxter Clavemarlton
    July 20, 2006 at 7:22 pm
    There is a function in FCP that is often overlooked… and it can help with many audio and video “skipping”, “sticking” and “missing” problems.
    You should “Mixdown” the Audio for playback before you dub out of FCP, or during the edit, if you have audio/video stuttering, drop-outs, sync-slippage, or freezes.
    NOTE: Mixdown has even been demonstrated to help with slipping, skipping problems (or “missing” audio clips) for files being EXPORTED as QT (or similar) files out of FCP.
    First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
    Sequence Menu > Render Only > Mixdown.
    You should see a dialog box telling you its rendering.
    It might seem to make little sense that “Mixing down” even simple audio tracks will “fix” complex video “freezes” or random audio dropouts to tape or export, but it CAN.
    NOTE: It does not matter of you only have one audio track, if there are random freezes during output, you should try the Mixdown.
    I think that this is one of the functions that is SUPPOSED to take place automatically during pre-processing of “Edit to… Master to… Print to…” but sometimes it may just not quite perform this completely.
    I flat-out NEVER use any of these playback “features” anyway. I always just hit “record” on the deck and PLAY the timeline out to tape.
  • Julie B
    July 20, 2006 at 7:34 pm
    Thanks Jerry. I must have missed this thread when I scanned through previous posts! I have my drive plugged into the front of my tower, and the deck plugged into the back. Doesn’t this make them on different buses? Sorry I didn’t mention thiis part before.
    Thanks again!
  • Julie B
    July 20, 2006 at 7:39 pm
    Thanks Thax. When I saw that it was rendering the audio (after I told it to print to video) I assumed that this was the final mixdown…but we all know what happens when one assumes 🙂 If it still drops frames after mixing it down, I’ll try your second suggestion. I have a feeling it drops frames on playback, though. I have the setting to tell me when it drops frames during playback turned off, but sometimes is “sticks”.
  • Mark Maness
    July 20, 2006 at 7:45 pm
    Nope, they are the same buss.
    You really need a seperate firewire card to solve this problem.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Julie B
    July 20, 2006 at 7:57 pm
    Oh. Thanks Wayne!
  • Dan Riley
    July 20, 2006 at 9:19 pm
    Thax,
    Hitting record and starting your timeline playback is fine if you are
    doing work where no one cares about your sequence timecode.
    But MANY of us in the pro world DO VERY MUCH have to provide
    our sequence timecode to various people. Like doing a layback
    for an out of house audio mix, or masters to a 1-800 dub house
    where they need my timecode info to put the 800# on the show
    where I want it. Or how about TC windows made on a different
    machine for clients to view and then give feedback based on TC.
    Your response that this is a “feature” is so over the top.
    Outputting to tape and editing to a specific timecode number is a
    BASIC part of any professional editing system. And unfortunately
    with FCP, it’s always been problematic, and a real reason why
    many AVID Media Composer users are reluctant to switch to FCP,
    (although her firewire issue is not what I’m talking about).
    Off on a tangent here I know, but that comment about “I only just hit record”
    got me going.
    Dan
  • Julie B
    July 20, 2006 at 11:09 pm
    Thanks for your input, Dan. I tried this method too…and dropped frames. The timecode doesn’t really matter on this particular master (it’s a backup that we will hopefully never need to use). However, that won’t always be the case and I do need to have the problem solved.
    So far, the only comments that I haven’t tried yet concern the firewire. Does anyone have any suggestions for a PCI firewire card?
    Julie
    _________________________________________________
    Mac OS X Dual 2.3 GHz G5, 2.3 GB RAM
    FCP 5 Studio, After Effects 6.5
  • Dan Riley
    July 20, 2006 at 11:24 pm
    Pick whichever flavor applies to your system here:
    https://eshop.macsales.com/shop/firewire/add-ons-and-hubs/pci-pcmcia-cards
    Dan
    July 21, 2006 at 3:10 am
    [Danrnw] “Off on a tangent here I know, but that comment about “I only just hit record”
    got me going.
    Thank you for the kind words.
    What is timecode used for in the pro world?
Page 1 of 3
