problems opening rendered project on dvd architect
Posted by Johnpaul Zerafa on January 11, 2012 at 8:35 pmHello,
I have some avchd footage that I editit in sony vegas hd platinum 11
So I rendered it for bluray with menus, but when I try to open it in dvd architect it wont allow me.
An error comes up saying file cannot be open.
Any ideas of what I might be doing wrong?
Im all new to this editing stuff
Any help would be much appreciated
ThanksJohnpaul Zerafa replied 14 years, 8 months ago 3 Members · 9 Replies -
Graham Bernard
January 12, 2012 at 4:28 amI have no experience of this BR workflow, but have you setup DVDA to BR?
I’m just guessing here.
Grazie
Stephen Mann
January 12, 2012 at 5:43 am[johnpaul zerafa] “So I rendered it for bluray with menus”
What type and what template did you use? (BTW, you don’t “render” MPEG or M2TS, these are encoded formats notwithstanding that Sony put the encoding formats in the “Render As” menus).
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Johnpaul Zerafa
January 12, 2012 at 9:48 pmHey thanks for the replys guys
Im not sure what u mean exactly when u said what template did I use
How can i find out?
Sorry but im just a beginer with little knowledgeAnd im using avchd isnt that the format or?
Thanks -
Stephen Mann
January 13, 2012 at 3:48 amWhen you do a “Render As” you need to select a type (MPEG) and a template (one of the DVD Architect templates). You then do another “Render As” and select “AC3” at the type. You need to bring the MPEG file into DVDA, and the AC3 file should move automatically.
Steve Mann
Johnpaul Zerafa
January 13, 2012 at 9:04 pmOk stephen il try it out
And thanks for all your help, il let u know how it turned out -
Johnpaul Zerafa
January 16, 2012 at 3:46 amhey stephen
i tried doing as you told me and im gonna explain to you in my own words what i didso i clicked (project) and clicked (render as) then the window popped up so i found MainConcept MPEG-2 and i went with DVD Architect NTSC Video stream, and again i did the same for the audio but only under ac-3. yes now i can open them on DVDA thanks to you
my only question is this, iv noticed that in DVDA i click on the same project that iv rendered from sony vegas its says
VIDEO: 720X480X32im only asking coz my camera records in 1080-60i and in vegas its also was 1080-60i
did i just lose video quality? in dvd architect
if yes
how can i use the same video quality in dvd architect the way it was recorded originallythanks again stephen
Stephen Mann
January 16, 2012 at 6:33 amDVD *is* 720×480.
If you want a 1080 disk, you nave to make a blu-ray.
Steve Mann
Johnpaul Zerafa
January 16, 2012 at 3:25 pmyes i know that
but when i choose Bluray 1920×1080-60i from the RENDER AS menu the format only that comes in is m2vi dont c any templates that say bluray for dvd architect
thanks
Johnpaul Zerafa
January 18, 2012 at 7:51 pmhi stephen
so i finally did render the video and the audio to dvda
when i did the menus and everything i clicked MAKE BLURAY DISKso it started rendering to disk and then this popped up saying…
An error occured while preparing compilation
File name: N/A
Status: StatusCodeTable.xml Err Status Code :[MUX_SN_E_IO]any idea why this could be?
thanks
