Activity › Forums › Adobe Premiere Pro › Problems in PP2
  • Problems in PP2
    Posted by Jonathan Shohet on May 26, 2006 at 8:03 pm
    I’m having two problems ever since moving to PP2 from PP1.5
    I really like the new PP2 and would hate to go back…
    1. I’m working with targa sequences as clips in premiere. somtimes I stretch the duration of the clips with frame blending turned on. There was never any problem with PP1.5 but now when I try to render the timeline, premiere generates an “unknown error” and doesn’t render the clip. I’ve noticed that if I cut the final few frames of the streched clip premire will render. This only happens with tga, PP2 does fine with jpgs tiffs or quicktime. However, I already have quite a lot of footage as tga sequences, so if anyone has a clue of what could be the problem it would be great.
    2. With PP1.5 I used a television monitor through the tv-out of my ati radeon 9600 with no problem. Now with PP2 I can’t seem to get anything…
    Thank you in advance if you can share some insight…
    Jonathan Shohet replied 20 years, 4 months ago 2 Members · 2 Replies
  • Aanarav Sareen
    May 27, 2006 at 8:02 am
    [dixie.fever] “2. With PP1.5 I used a television monitor through the tv-out of my ati radeon 9600 with no problem. Now with PP2 I can’t seem to get anything…”
    ATI would have to create drivers for this issue.
    Regarding problem 1: I have seen this error come up soooo many times, that there is no solution. I know that this doesn’t help you, but I will try this specific scenario out and post back.
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Jonathan Shohet
    May 27, 2006 at 10:09 pm
    thanks for the reply.
    At least I know that the targa problem is a known one and not just a problem with my system.
