Activity › Forums › Apple Final Cut Pro Legacy › Problems in FCP 2 after Mac OS Update
  • Problems in FCP 2 after Mac OS Update
    Posted by David Cooke on August 21, 2009 at 1:32 pm
    Like many editors, we use( “Command H” and/or “Option-click a blank area of your desktop) to hide
    Final Cut to easily go to and from other programs in use. Now after updating our MAC OS, when
    we do this to FCP, the dock still has the indicator (blue dot) that the program is running, but it is NOT.
    We have to RESTART to get FCP back. This is the first real problem we have ever had with our
    MAC and FCP system since installing 2 and 1/2 years ago!
    Do we need to go back to a previous OS version? Is there a patch?
    Just upgraded to Leopard 10.5.8
    Intel Dual 3.ghz with 4 Gig ram.
    FCP is 6.0.6
    D’s Video
    Paul Dickin replied 17 years, 1 month ago 3 Members · 4 Replies
  • Rafael Amador
    August 22, 2009 at 4:07 am
    Hi david,
    I would suggest you to run DiskWarrior, TechTools or DriverWizar.
    Cheers,
    rafael
    http://www.nagavideo.com
  • David Cooke
    August 24, 2009 at 12:33 pm
    Thanks Rafael. Will give it a try. We used diskwarrior on our old MAC editing system-Affinity
    and it was a great tool.
    D’s Video
  • Rafael Amador
    August 24, 2009 at 3:19 pm
    Hi David,
    If you install from scratches MacOSX, QT and FCS, and you run DiskWarrior, you will find more than 30% of “items out of order”.
    No way to work like that.
    Cheers,
    rafael
  • Paul Dickin
    August 24, 2009 at 3:32 pm
    Hi
    Have you tried Cmd-Tab to switch back to FCP as the active application?
