Activity › Forums › DaVinci Resolve › Problems downloading the Resolve 9 manual.
Posted by Steve Davies on August 5, 2012 at 5:52 pmHi, Has anyone managed to download the Resolve 9 manual? For me it stops at 2.06MB out of a total of 46MB.
Steve Davies replied 14 years, 1 month ago 4 Members · 7 Replies -
Brandon Thomas
August 5, 2012 at 7:04 pmno issues for me. It should also be included when you download the installer.
Steve Davies
August 5, 2012 at 7:32 pmNope, I just got one file: ResolveLite-Win-9.0.exe and there is no manual in with the Program Files and the Help does nothing. I tried downloading the Mac manual but that stops as well.
I’ve just tried downloading the program again, in case I missed something, but it’s asking me to register again and there appears to be no way to login. It looks like I’m going to have to re-install 8.22 (9 kindly deleted it) as I’m using whole files which have to be split into clips and the clip splitter/editor in 9 doesn’t work.
Joseph Owens
August 5, 2012 at 7:50 pm[Steve Davies] “the clip splitter/editor in 9 doesn’t work.”
Worked for me.
The manual should come along with the upgrade in the .dmg package.
jPo
“I always pass on free advice — its never of any use to me” Oscar Wilde.
Steve Davies
August 5, 2012 at 8:00 pmdmg is Mac, I’m using Windows. The scene detector is constantly greyed out. The display in the Master viewer doesn’t correspond to the cursor position and Split-Clip cuts at a random point and so is uncontrollable.
Steve Davies
August 5, 2012 at 8:04 pmAlso Exporting only allows either 23.98 or 24 fps and not 25, so the delivery is useless.
Peter Chamberlain
August 6, 2012 at 12:38 amHi Steve, if you go to the Bmd support page for windows lite you should be able to download the manual from there. To put a clip into the scene cut detector, first make sure your Frame rate is set correctly, then select the clip in the library, rt click and send to scene cut.
Peter -
Steve Davies
August 6, 2012 at 7:02 amThanks Peter.
The scene detect is working now but ‘Export’ still only gives me the option of 23.98 or 24fps no matter which other export settings I choose. All settings show 25fps except in ‘Scene Detect’: when I click ‘Add Cuts to Media Pool’ I get ‘Are you sure you want to use these Parameters?’, and it shows the frame rate as 24fps but gives no way to change it; the only option is Cancel which just cancels the box or OK which accepts those settings.
Any help appreciated.
