Activity Forums Avid Media Composer Problems Batch Capturing a 720p decomposed sequence
  • Problems Batch Capturing a 720p decomposed sequence
    Posted by Corey Norman on October 28, 2008 at 2:25 pm
    Hi All,
    So I’ve been running into an issue lately. I’m working from a sequence that was captured in 480i/29.976. I decomposed the sequence and then went to batch capture it again at its true resolution of 720p/ 59.98. When doing so I get the following error:
    Cannot capture media due to lack of drive space
    However, I’m working with an empty 1.5TB drive!!! I even tried 3 other drives with the same results. I can crash record the segments just fine, but this is not an ideal workaround as it drastically increases my online time having to cut clips in by hand.. I can log and batch capture from the tape just fine, but I can not from the decomposed sequence.
    I flipped my project into 1080i mode and batch captured from the same decomposed sequence. I set my DVC Pro HD deck to export 1080i footage and this worked flawlessly.
    So it seems like I just can’t batch capture from the 720p sequence. Does anyone have any ideas?
    I’m using an AVID Adrenaline with media composer 3.0 software.
    Corey Norman replied 17 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
