Activity Forums Apple Final Cut Pro Legacy Problems Assembling Edit to Channel 3&4 – DVW A-500 DigiBeta.
  • Problems Assembling Edit to Channel 3&4 – DVW A-500 DigiBeta.
    Posted by Paul Factora on January 20, 2007 at 12:01 pm
    Not sure what I’m doing wrong.
    I’m going out of a Canapus box that has only 2 audio outputs.
    Channels 1 & 2 recorded fine.
    -I switched the plugs to go in 3&4 inputs on the Deck.
    -Muted 1&2 and did an insert Edit. No levels…
    -I get a preview tone that gets levels on the deck but none during the Insert edit.
    On the deck panel only channels 1&2 buttons light up.
    Any ideas?
    Much Thanks,
    Paul
    Travis Ballstadt replied 19 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • Mark Raudonis
    January 20, 2007 at 3:32 pm
    Go here, it’s free: https://movielibrary.lynda.com/html/modPage.asp?ID=180 Click on “Setting up for multichannel output”.
    This tutorial on Lynda.com explains exactly how you need to set up your system for mulichannel output.
    A year of total access only costs $250 bucks. Considering how many hours of tutorial they have, it’s a bargain.
    Mark.
  • Paul Factora
    January 20, 2007 at 7:23 pm
    thanks for the link but my audio tracks settings appear to be ok.
    Is there any other reason I’m not getting levels on 3&4? The 3&4 lights on the VTR deck panel do not light up.
  • Paul Factora
    January 20, 2007 at 7:39 pm
    this is crazy. I have Tracks 3&4 set to Output 3&4 on the timeline but the Master levels I am getting in Tool Bench are 1&2.
  • Jeremy Garchow
    January 21, 2007 at 2:37 am
    Open the audio mixer and unclick the ‘downmix’ button.
    Jeremy
  • Joe Paolo
    January 21, 2007 at 8:01 pm
    Are you enabling channels 3 & 4 in the edit to tape window?
    joe
  • Paul Factora
    January 22, 2007 at 4:41 am
    Thanks Jeremy
  • Travis Ballstadt
    January 26, 2007 at 4:21 am
    You don’t want to route your audio to output 3&4 if your device only has 2 channel output. It will never see 3&4.
    You want to mute the stuff you already sent in the first pass, then send your new mix to channels 3&4 on the deck by moving the cables.
    travis ballstadt
    http://www.thrillcateditorial.com
