Activity › Forums › Adobe After Effects › Problematic white areas in key.
  • Problematic white areas in key.
    Posted by Anthony Light on March 20, 2009 at 7:28 pm
    Just wondering if someone might be able to give me some pointers on correcting a problem with keying some footage.
    Footage is DVCPRO HD 720p60 via FCP log and transfer from p2 card data. Not sure how the footage was shot, just asked to do post (panasonic HVX200 maybe? pretty grainy footage).
    I created a core matte and then layered individual keys (keylight) for my edges, masked out, etc. for each major area (hair, arms, legs, feet, etc.).
    The problem is that I’m getting some areas on the talent that are showing up white and I’m at a loss as how to remove them.
    The problematic areas are seemingly areas that light got through, but not enough for the camera to recognize as green (?) from the screen. Areas like between the legs, under the arm between arm & body, etc.
    Source footage zooms show up as white pixels.
    I’ve posted several images.
    Picture 1 – key’d footage on black, white showing
    Picture 2 – source footage
    Picture 3 – close up source footage
    Picture 4 – close up key’d footage
    This may be something pretty obvious, but I’m at a loss as to how to correct/adjust it.
    I’ve searched the forums for answers, but haven’t found anything similar. Any help would be greatly appreciated.
    Thanks.
    Anthony
    Anthony Light replied 17 years, 6 months ago 3 Members · 3 Replies
  • Roland R. kahlenberg
    March 20, 2009 at 8:08 pm
    See if the Multiply Blending Mode works.
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available)
  • Chris Wright
    March 20, 2009 at 9:27 pm
    I checked out the source image and its definately a spill issue, work with the spill settings, transparency, shrink matte. And I suggest separate keys for the white areas. A fast oval junk matte would probably take less time then tweaking it to death though.
  • Anthony Light
    March 20, 2009 at 9:57 pm
    Thank you all for the replies and suggestions. Pretty new to a lot of this, so pardon my followup questions:
    @Dave Would I be applying this to the comp nested in a new comp with multiple instances/layers, for each trouble spot?
    @Roland – multiply blending mode – how? Existing layers or new, additional layers?
    @Chris – can you elaborate a little re the spill settings and transparency?
    Many thanks.
