Activity Forums Zaxwerks Problem wrapping texture around object
  • Problem wrapping texture around object
    Posted by Patrick Lajko on July 21, 2006 at 9:30 pm
    I have a problem wrapping a texture around an object.
    It is a bowling pin created in Cool-3D Studio then exported as a 3ds file. Swift 3D imports it with no problem.
    In ProAnimator I imported the 3ds object then added the texture material (a TGA file for the image of a bowling pin surface). All looks OK except a narrow wedge that seems to have everything blurred.
    Is there any way to find the cause of this?
    Serge Hamad replied 20 years ago 2 Members · 3 Replies
  • Serge Hamad
    July 21, 2006 at 9:44 pm
    It sounds like a bad UV mapping issue. If you have 3DS, import your object and apply a new UV mapping.
    BTW. Why don’t you just create the bowling pins using a custom edge?
    Have a look at https://www.nyc-visual.com for an example.
    Salut.
    Serge
  • Patrick Lajko
    July 22, 2006 at 12:58 am
    I’ll try your suggestions.
    Being new at ProAnimator, I hadn’t thought of wrapping a custom edge around a stick.
    If I have to redraw it, I will. That’s easy compared to the work we did to create a dozen realistic bowling pin surface textures. The pin is really 2 objects: the pin body and the base.
    I saw a bowling pin on your site. I emailed you an example of what we have been doing. We’re making animations for Brunswick scoring systems. Proanimator excites me because of the ease of animating text – like “SPARE” or “Perfect Game” and it has true shadows that fall on objects (which Cool 3D doesn’t have)
  • Serge Hamad
    July 22, 2006 at 5:24 am
    [Patrick Lajko] “Being new at ProAnimator, I hadn’t thought of wrapping a custom edge around a stick.”
    I am not sure if you got me right here. You should apply a custom edge to a tinny circle not a stick. Let me know if you need more help on this one.
    [Patrick Lajko] “I emailed you an example of what we have been doing.”
    I didn’t get anything. E-Mail me again if you want at (serge_01 at msn dot com)
    Salut.
    Serge
