Activity Forums Maxon Cinema 4D Problem with Y-axis Rotation in Rudder Animation in Cinema 4D R24
  • Problem with Y-axis Rotation in Rudder Animation in Cinema 4D R24
    Posted by Mauricio Barrientos on August 22, 2024 at 8:29 pm
    Hi, I have a problem, I really need help. I’m using Cinema4D R24, and I want to animate a rudder so that it rotates only around the “Y” axis. But when I rotate it and record it on the timeline, it has a weird wobble, a back-and-forth motion. I’m leaving a video LINK below… My question is, why, if I only dragged the rotation of the “Y” axis, did it affect the other two axes? And how can I fix this, please, since it’s not the first time this has happened… I would really appreciate any help…
    https://youtu.be/Isnjs4aTqG8
    Kouraib Abdmalek replied 2 years ago 3 Members · 8 Replies
  • 8 Replies
  • Kouraib Abdmalek
    August 23, 2024 at 7:25 am
    Hi Mauricio,
    The axis of the object might be slightly off. You could use the Centre Axis To tool and try again. If the situation doesn’t improves, please post your file so I can check it.
  • Mauricio Barrientos
    August 23, 2024 at 1:33 pm
    Yes, brother, I checked the axes and that was it… they were misaligned. In fact, I’m also leaving the file here… but I have a question… is it possible to tell Cinema that even if it’s misaligned, to only rotate the “y” axis, for example? Because there are situations where the pivot needs to be misaligned… otherwise, I would have to bring all the objects to zero, fix their axis, and then take them like a child in the hierarchy to return them far to their position… that’s why I’m asking if… even when it’s misaligned, can we LOCK the axes that we don’t want to rotate in the timeline? … thanks again.
  • Kouraib Abdmalek
    August 24, 2024 at 10:47 am
    The axis misaligned only affects if you select more than one object and record their rotation in the timeline, but if the objects are under Null Object so you will not need to make it aligned, I opened the file you sent and it works fine without any wobble! as the screen recording below, did you make any changes to the axis locations or to the workspace?
    August 26, 2024 at 2:12 pm
    sorry for delay…. I think I’ve solved it by aligning the axis and the axes first… I just want to know if it’s possible to lock an axis, like putting a little lock on it before rotating? Is that possible?
  • Kouraib Abdmalek
    August 27, 2024 at 7:36 am
    No worries! yes, you can lock an axis by pressing Ctrl and double-clicking on the axis the axis color will turn yellow or white in the last versions then you can unlock it again in the same way Ctrl double-click as in the screen recording below, let me know if that works for you.
    August 28, 2024 at 1:42 pm
    wow awesome ….. really thanks ….. bless
    work doble clik on verison before 23 but in R24 not work if i doble click to lock rotation axis …..
  • Kouraib Abdmalek
    August 29, 2024 at 7:00 am
    You are welcome, Mauricio! As for R24 I’m not on my pc now but I think what’s different is not holding Control with the double-click to lock or unlock, I’m not sure.
    August 31, 2024 at 2:17 pm
    Hey Kouraib, thanks again… I went to test it, and yes… it works on Mac Ventura with the key pressed and double-clicked. And what’s more… the amazing thing is that it shifts and rotates the axis, which is why I started this post. And on the timeline, IT WORKED… wow, amazing, awesome… once again, very grateful… blessings!!!! Kouraib
  • Brie Clayton
    September 1, 2024 at 1:16 am
    Thanks for solving this, Kouraib!
