Activity › Forums › Apple Final Cut Pro Legacy › Problem with watermark
  • Problem with watermark
    Posted by Christian Proulx on October 3, 2007 at 12:22 pm
    Hi guru,
    first of all, excuse my written, I am a fernch canadian…
    I tried to put a watermark on my sequence for delivery on the web. The setting for the sequence is 1920X1080 29,97 fps (using Apple Prores 422 HQ).
    When I use the Boris Title 3D generator, it works fine on V2 with Overlay composite mode, but when I use a Motion clip (black background with a white text only, I export the clip with the same setting of my sequence from FCP6) to create some motion in my lowerthird, the composite mode go really to dark, the overlay do not work, I have to go with the difference setting instead.
    Any idea what is wrong with my process?
    Thanks for your help, great source of information on your site.
    Have a nice day everyone.
    Christian
    David Battistella replied 18 years, 12 months ago 2 Members · 1 Reply
  • David Battistella
    October 3, 2007 at 2:54 pm
    Christian,
    Try to KEY the footage instead of using overlay mode. You can also render the footage out of motion with an Alpha Channel. This should have it KEY automatically.
    David
