Activity Forums Adobe Premiere Pro problem with warp stabilizer
  • problem with warp stabilizer
    Posted by Oluwagbemisola Oluwayimika on September 7, 2013 at 6:24 pm
    I have just finished applying warp stabilizer but it show me a sign that reads like this”To avoid extreme cropping set framing to stabilize only or adjust other parameters” I tried to adjust as said but I git the same sign.Please, how do I go about this.I have apply to other other clips and I receive the same message.Please help
    Andie Moonie replied 12 years, 11 months ago 4 Members · 3 Replies
  • Ivan Myles
    September 7, 2013 at 7:18 pm
    Please post your settings.
  • Ann Bens
    September 8, 2013 at 12:23 pm
    The warp stabilizer can perform wonders it cannot perform miracles.
    Most but not all clips are suited for the warp. Heavy motion for instance.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Andie Moonie
    September 9, 2013 at 6:07 am
    Also make sure you have not set the motion parameter to “no motion” instead of “smooth motion” as this will create to much cropping and scaling if there is significant movement in the clip
