Activity › Forums › Adobe Premiere Pro › Problem with video playback
  • Problem with video playback
    Posted by Anth Pun on January 13, 2010 at 7:55 am
    I opened Adobe Premiere Pro CS4 and then I imported a short clip. When I played it on the time line to check where to edit, the audio runs normal but the video itself only moves ONE frame as if it is on frame hold. It worked perfectly yesterday, why is it freezing on me today?
    Brian Louis replied 16 years, 8 months ago 3 Members · 3 Replies
  • Ann Bens
    January 13, 2010 at 11:35 pm
    Download Gspot from the web and let it analyze the clip then post a screendump.
    https://www.headbands.com/gspot/
  • Anth Pun
    January 14, 2010 at 3:30 am
    Hmm I appreciate the help but I think the clip itself is fine because I can play it on windows media player. Its premiere’s fault (pretty sure) because I THINK I pressed something while I was editing and anything can’t be played properly in the edit preview screen.
  • Brian Louis
    January 14, 2010 at 10:18 pm
    [Anth Pun] “Hmm I appreciate the help but I think the clip itself is fine because I can play it on windows media player”
    Whether or not it plays in Media Player has nothing to do with working in Ppro, a request for help should include, the type and parameters of the clip, your project settings are, what operating system you are using, what version of premiere pro you are using(which you have), and a description of your computer, and what you did in the workflow to get where you’re at.
