Activity Forums Adobe After Effects Expressions Problem with the order of actions. how to create a slider without losing the original property selection array
  • Problem with the order of actions. how to create a slider without losing the original property selection array
    Posted by Tal Arbiv on December 12, 2016 at 12:33 am
    I’ve got a double ‘for’ loop creating expressions on a selected properties of selected layers. the expression contains reference to a slider that is created on current layer within the same loop.
    problem is, if i place the slider creation after the expression assignment, the non existing reference breaks the loop,
    and if i place it after, my guess is that it replaces the active selection of the original property with the newly created slider and that messes up the rest of the loop .
    result 1 : faulty expression
    result 2 : expression assignment skipped
    // (1) :
    expr = “effect(‘name’)(‘slider’) //+something+something…. ;
    for (i=0; i <= sellayers.length-1; i++){
    for (p=0; p <= selprop.length-1; p++){
    selprop[p].expression = expr;
    ofset = sellayers[i].Effects.addProperty(“ADBE Slider Control”);
    ofset.name = “name”;
    ofset.property(“Slider”).setValue(0);
    // (2) :
    Big thank you in advance
    // (1) :
    expr = "effect('name')('slider') //+something+something.... ;
    for (i=0; i &lt;= sellayers.length-1; i++){
    for (p=0; p &lt;= selprop.length-1; p++){
    ofset = sellayers[i].Effects.addProperty("ADBE Slider Control");
    ofset.name = "name";
    ofset.property("Slider").setValue(0);
    // (2) :
    Tal Arbiv replied 9 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
