Activity Forums Maxon Cinema 4D Problem with spline wraps, small bit of geometry appearing on end of spline
  • Problem with spline wraps, small bit of geometry appearing on end of spline
    Posted by Josh Smith on March 18, 2016 at 2:44 pm
    Hi guys, I’m new to C4D so just learning! I have an issue where a tiny bit of geometry is still showing at the end of the spline (the little orange square, image below) and for the life of me can’t get rid of it. The only solution I found was shrink the height of the cube to 0 but then that ruined the shadows on the shape, or turn off visibility. Any help? Thanks
    https://imgur.com/lvWchKA
    View post on imgur.com
    Jim Scott replied 10 years, 6 months ago 2 Members · 3 Replies
  • Jim Scott
    March 18, 2016 at 4:45 pm
    Josh,
    It’s hard to see the details in the image. Perhaps you could attach your project file so that others could find it easier to help.
  • Josh Smith
    March 18, 2016 at 4:48 pm
    Unfortunately it’s at work and I’m no longer there! I’ll try remember to share it on Monday, hopefully I do!
  • Jim Scott
    March 18, 2016 at 4:55 pm
    Ok, I’ll watch for it.
