Activity Forums Apple Final Cut Pro Legacy Problem with speed change HD to SD
  • Problem with speed change HD to SD
    Posted by Isaac Orcino on August 3, 2010 at 9:07 pm
    Hello guys,
    I having a problem when a i change speed in final cut with HD videos. We usually capture our material in 108060i 29,97 DVCPROHD but when I downconvert to SD every video that we changed the speed jiggles, its like flicks. Trying to solve the problem, I found out that if I change the sequence setting (8-bit uncompressed) from lower field to upper field it does not flick. Is there another way I can downconvert to SD without flicking with lowerfield? or can I just leave in upper field?
    I’m using an Intensity from BlackMagic to output the SD video to Betacam.
    Isaac Orcino
    Goiânia,Goiás, Brazil
    +5562 91181638
    Shane Ross replied 16 years, 1 month ago 2 Members · 1 Reply
