Activity Forums Audio Problem with SoundDevices MixPre-D
  • Problem with SoundDevices MixPre-D
    Posted by Juan luis Gomez on April 6, 2014 at 10:22 am
    I have just received this great little mixer for sound recording… And It’s driving me crazy because I don’t know how (maybe I just pressed some weird front panel button shortcut or something) but the only thing I can make of it is turning the “return signal led” on.
    This is probably me being a mere idiot because I am a video oriented guy. Anyway, when I turn on the mixer powered by two internal batteries the only led light working it’s the “return signal led” instead of the “led above the power switch”.
    I have tried to set up a pair of shotgun mics (NTG-2) supplying and not supplying them phantom power from the mixer but the led vumeters doesn’t turn on and there is no input signal in any case. I have tried it with the tone oscillator as well with the same result: nothing.
    I have just written to SoundDevices technical support but, as I said, this is driving me crazy and I guess it has an easy solution that I can’t figure it out so I wanted to check here if anyone has a solution before they write me back.
    Can anyone help me with this weird personal problem?
    Sorry for my english, it’s not my mother language.
    Thanks.
    Nigel Francis replied 11 years, 9 months ago 2 Members · 1 Reply
  • Nigel Francis
    December 1, 2014 at 2:06 am
    Did you fix this? My MixPre-D is not working. I only have power and nothing else, no tone, no slate mic, nothing.
