Activity Forums Zaxwerks problem with rotation around an axis
  • problem with rotation around an axis
    Posted by Banshee on June 17, 2005 at 10:38 am
    hi all,
    I now succeeded in rotating seperate characters around the y-axis. Because I didnt like the standard bevel depth I decreased it. But now the y-axis isnt exactly in the middle of the characters but behind them so that they dont seem to turn but even change their position while rotating. I hope you can imagine this :]
    Do you know how I can apply the y-Axis to that?
    Matt Rhodes replied 21 years, 2 months ago 2 Members · 3 Replies
  • Matt Rhodes
    June 17, 2005 at 4:39 pm
    Hi Banshee.
    I assume you’re using ProAnimator v3.0.
    The object pivot isn’t properly adjusted when changing the depth of the object.
    In version 4 (coming soon), the objects are created so that the pivots are properly centered.
    Matt Rhodes
    Zaxwerks, Inc.
  • Banshee
    June 18, 2005 at 9:22 am
    No, I was using the 3D Invigorator v4.0.3 but I guess its the same problem.
  • Matt Rhodes
    June 18, 2005 at 8:33 pm
    Yes. It’s the same problem.
    However, version 4.0.5 (released very soon) will fix this problem
    by creating the object in a slightly different way.
    Matt Rhodes
    Zaxwerks, Inc.
