Activity › Forums › VEGAS Pro › Problem with rendering in Sony Vegas
  • Nigel O’neill
    September 9, 2011 at 2:50 am
    Looks like deinterlacing issue. Try setting Deinterlacing Method to blend fields
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • John Rofrano
    September 9, 2011 at 12:20 pm
    [Dragomir Ralchev] “The settings are the following:”
    Your project settings are wrong. 24.000 (Film) is for working with film transfers. Since your Nikon D90 doesn’t shoot film you should not be using this setting. Use the built-in Sony template HDV 720-24p (1280×720, 23.976 fps) instead.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dragomir Ralchev
    September 9, 2011 at 8:15 pm
    Both advices didn’t help :S
  • John Rofrano
    September 9, 2011 at 8:36 pm
    [Dragomir Ralchev] “Both advices didn’t help :S”
    What are your render properties? Which template are you using?
    ~jr
  • Dragomir Ralchev
    September 10, 2011 at 10:58 am
    I am using the same settings, as my project.
    MainConcept codec, WMV, both are smoothing the video.
  • John Rofrano
    September 10, 2011 at 1:51 pm
    [Dragomir Ralchev] “I am using the same settings, as my project.”
    You didn’t say which render template you are using? We can’t help you if you’re not going to answer our questions.
    Can you post a screen capture of your render settings at least?
    ~jr
  • Dragomir Ralchev
    September 11, 2011 at 9:51 am
    https://img28.imageshack.us/img28/3694/720pt.jpg here is a screenshot of my render settings.
    Thank you
  • John Rofrano
    September 11, 2011 at 3:32 pm
    It looks like you built your own template instead of using one of the templates supplied by Sony. Unless you’re an expert, I wouldn’t advise that.
    Try using Sony AVC instead of MainConcept AVC with one of the built-in “Internet 720p” templates. Change the frame rate to 23.976 fps if you have to. Don’t change anything else other than bit rate.
    Also, when you right-click on an event and go to Properties | Media what frame rate is Vegas showing for your footage? I’m guessing that somewhere alone the line the frame rates don’t match.
    ~jr
