Activity › Forums › Adobe Premiere Pro › Problem with rendered work area in CS6
  • Problem with rendered work area in CS6
    Posted by Mladen Ilic on October 11, 2012 at 8:40 am
    After editing and grading, I need to render the work area so I can see if everything is OK. When I render the work area everything works as it should, but when I close the project and turn off the computer, tomorrow, when I open it again, the work area isn’t fully rendered!
    So I need to render the work area once again, and it’s time consuming…
    This never happened with CS5, unless I clear the cache with a program like ccleaner, but I’m not doing this now and still some parts of the work area aren’t rendered when I open the project again..
    Why is this happening?
    Thanks everybody.
    Mladen Ilic
    Mladen Ilic replied 13 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
