Activity Forums Apple Final Cut Pro Legacy problem with realtime effects
  • problem with realtime effects
    Posted by Tomas Daliman on July 4, 2006 at 5:38 pm
    I have a problem with FCP5. When I make a dissolve transition between two clips then during playback the picture jumps few lines up and goes a bit to green color. While I render it, problem dissapears.
    I thougt that it’s some problem with realtime playback, but I have Quad G5, 4,5GB RAM and I am editing DVCAM (PAL) project. Is there any way how to solve this problem?
    Tomas Daliman replied 20 years, 2 months ago 5 Members · 8 Replies
  • 8 Replies
  • Kevin Monahan
    July 4, 2006 at 6:31 pm
    Are you in Safe RT or Unlimited RT? Have you trashed prefs?
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Arnie Schlissel
    July 4, 2006 at 6:50 pm
    [TomasD] “While I render it, problem dissapears.”
    That’s your answer. Your dissolve wasn’t rendered.
    Arnie
    https://www.arniepix.com
  • Tomas Daliman
    July 4, 2006 at 8:18 pm
    I’ve tried both, but result was same
  • Tomas Daliman
    July 4, 2006 at 8:29 pm
    I think that FCP might do dissolve realtime in full quality – when I’m editing with Avid or Adobe Premiere pro, basic transitions were always realtime and in full quality, even in SD resulotion. So, DVCAM due to it’s bitrate migh be a piece of cake for a machine such as quad G5… am I wrong?
  • Ron James
    July 5, 2006 at 6:45 am
    I don’t think you should be seeing this. Check your sequence settings. I’m not at my machine at the moment, but I think you might want to check your white/superwhite/RGB setting. Is this still an option?
  • Tomas Daliman
    July 5, 2006 at 7:52 am
    Yes, I’ve tried every single method of video processing, but without effect 🙁
  • Mark Maness
    July 5, 2006 at 1:08 pm
    Tell us a little more about your configuration. What capture card are you using? How are you monitoring your output?
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Tomas Daliman
    July 6, 2006 at 9:14 pm
    Quad G5, 4,5GB RAM, 2xCinema display 20inch, HDV/DVCAM deck SONY HVRM15U PAL, Capture thru FireWire 400, video preview only on cinema display in monitor window.
