Activity Forums Adobe Premiere Pro Problem with Quicktracks for PremierePro CS4!
  • Problem with Quicktracks for PremierePro CS4!
    Posted by Dario Cavallo on March 18, 2010 at 11:13 am
    I updated my Quicktracks to lastest version 3.12 and engine version 3.0.9.0.
    I installed it on PremiereProCS4 v.4.2.1 as Administrator.
    But I got a strange problem:
    1) When I go to select music an hit create button some times the file doesn’t create at all!
    Especially when I create a new folder called for example: “Quicktracks_Audio”, and put on it all the sound files made with Quicktracks.
    The file doesn’t create at all!
    Or Quicktracks create the file but Premiere doesn’t import it in the Project Window, and when I try to import it manually, appears the following message:
    -File corrupted (or damaged)…
    And I cannot import any file.
    2) Some times I created the Quicktracks sound file in the same root folder of the Premiere Project, and the creation process run successfully…
    3) Is this a Quicktracks BUG?
    Please response me!
    Horsepower.
    Dario Cavallo replied 16 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
