Activity Forums Blackmagic Design problem with outputting HD to SD use blackmagic decklink extreme
  • problem with outputting HD to SD use blackmagic decklink extreme
    Posted by Noor Maulana on January 11, 2010 at 8:16 am
    hi,
    we are using blacmagic decklink extreme card, and we have some problem about output from HD (compressor DVCPRO1080i50) to SD (betacam SP):
    the video image on the tv screen are interlacing and the line image has flickering.
    just for information.
    our setting on blackmagic decklink extreme preference.
    setting: – set output: SDI & HDMI & Y,R-Y, B-Y
    – set input : SDI video & SDI audio
    processing: – select output processing: off
    – select input processing: off
    and our audio/video setting on final cut pro:
    sequence preset:blackmagic PAL-10bit
    capture preset: blacmagic PAL-10bit
    device control preset: blackmagic PAL 25Hz
    video playaback: blackmagic PAL-10bit (720×576)
    thank you for your help.
    Noor Maulana replied 16 years, 7 months ago 2 Members · 2 Replies
  • Kristian Lam
    January 14, 2010 at 10:52 pm
    Hi Noor,
    You should be using the output processing option in the Blackmagic preferences instead of trying to put a 1080i50 into a PAL timeline in Final Cut Pro. This means using a 1080i50 project in Final Cut Pro and let our drivers handle the down conversion to PAL.
    regards
    Kristian Lam
    Blackmagic Design
  • Noor Maulana
    January 20, 2010 at 12:52 pm
    hi kristian
    it`s working. thank you very much for your help and i have question.
    do we need mini converter blackmagic SDI to analog? is that make our video resolution output better or not?
    regards
    noor maulana
    video editor
    digimage production Brunei darussalam
