Activity › Forums › Adobe After Effects › problem with motion blur, Text and ‘shutter angle’.
Posted by John Clark on March 19, 2006 at 2:52 amI don’t know why AE uses this ‘camera’ term, however, I don’t get a motion blur when using text (all in one photoshop layer, and moving the text.
There does not seem to be any blur of the ‘text’.
When using this feature, does each character have to be on its own layer.
John ClarkJohn Clark replied 20 years, 6 months ago 3 Members · 4 Replies -
Steve Roberts
March 19, 2006 at 3:04 amDid you switch on motion blur for the PSD layer and for the comp?
More info should be in the help under “motion blur”.
John Clark
March 19, 2006 at 3:05 pmI’ve eliminated the ‘psd’, and just created a layer with a solid bar, 128 pixes wide, and moves across a 720 pixel wide band in 5 seconds, which gives about 144 pixels of movment per frame.
I definately don’t see any indication of ‘blur’ with this set up, with motion blur option selected and varying the shutter angle between, 60-720.
As a note, I don’t know what 720 ‘really’ does as the basic frame rate is 24 fps. Does this mean that ‘motion blur’ should be spread across 2 frames?
Also as a note, when I use a ‘filter’ option such as the time echo, I see the effect of the echo rendered in the composite window. I don’t see this ‘blur’ option.
Basically I would like to use this option to ‘smooth’ the movement of sharply defined objects, such as text, to give it a more ‘natural’ look, relative to ‘real movie’ camera effects or artifacts.
John Clark -
Sam Moulton
March 19, 2006 at 3:10 pmmotion blur must be active in both the layer and the timeline. press both buttons. if that fails add ccforce motion blur.
John Clark
March 19, 2006 at 3:33 pmOk, A ‘careful’ reading of the help page indicates that in order to see the effect in the composition window, one needs to enable the motion blur icon in the top part of the timeline window…
Since I didn’t see the effect in the preivew window, I didn’t render to check to see if the ultimately rendered output had the effect, or not… (I thought I had done that at one point… but in the heat of battle…)
John Clark
