Activity Forums Maxon Cinema 4D Problem with limits in IK
  • Problem with limits in IK
    Posted by Facundo Maldonado on February 15, 2011 at 12:56 pm
    Hi! I’am working with Joints and Inverse Kinematics (IK).
    When I set the limits of a Joint (in the ‘Kinematics’ section), all works fine, as long as the joint it is not the first joint of the IK chain.
    Howeber, when I set the limits of the first Joint (‘Joint.0’) of the IK Chain, they are ignored, since the Joint rotates witch complete liberty (ignoring the limits that I set).
    What I have to do in order to limit the rotation of the first Joint of a IK Chain when I use Inverse Kinematics (IK)?
    (PD: Sorry for my bad english)
    Corrado Carlevaro replied 15 years, 5 months ago 3 Members · 4 Replies
  • Corrado Carlevaro
    April 2, 2011 at 11:06 pm
    same problem here
    corrado
  • Brian Jones
    April 3, 2011 at 5:12 am
    moving the IK tag to the second joint in the chain will freeze the first ‘bone’ but that’s an all or nothing thing.
  • Brian Jones
    April 3, 2011 at 5:59 am
    the only other thing I can see so far is to add a Constraint tag to the second joint and use it to Surface constrain to a hemisphere.
  • Corrado Carlevaro
    April 4, 2011 at 12:19 pm
    Thank you Brian, I’m trying some workarounds with Costraints but so far the best I can achieve is not using joints at all, just Null and costraints (Aim, Up)
    Corrado
