Activity › Forums › Adobe After Effects › Problem With Keylight 1.2
  • Brendan Coots
    March 1, 2009 at 7:20 pm
    Sometimes the frames AE has cached can get corrupted or suffer other oddities and they simply need to be flushed and replaced with good frames. Try doing Edit>Purge>Purge All. This clears your cache and will usually remedy the problem.
    Once you clear the cache, re-render and see if it’s still occurring.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Derek Pa
    March 2, 2009 at 1:00 am
    Thanks for the help, unfortunately it didn’t work, I tried twice. Is there anything else I could do?
  • Derek Pa
    March 2, 2009 at 1:15 am
    I figured out what was wrong, it was the video file. I had to convert the video file to .wmv for the problem not to happen. I was using a JVC digital video camera to record and the videos were saved in .mod format and I changed them to .mpg for the video(not by converting the video, but by changing the extension)
