Activity › Forums › Adobe Illustrator › Problem with intersect
  • Steve Crook jr
    June 17, 2015 at 3:35 pm
    Hi. I’m not sure WHY you want to compound them. If they are just going to stay there visually – leave them grouped and go on.
    BUT, I’ll be happy to answer your question under the assumption that you need to work with them further. 🙂
    What is causing your problem is that the two V-ish objects are stroked lines, and you need them to be filled paths.
    So, select them and Object > Expand and click OK. Now, to make them into a compound path, make sure both are selected and Object > Compound Path > Make *OR* press CTRL-8. You now have a compound path that looks exactly like the two lines did.
    Hope it helps.
    Steve Crook, Jr.
    http://www.stevecrookjr.me
    I am a simple creative professional that can get my Adobe suite and a few other creative tools to do what I want. Barely. 🙂
  • Saeb Molaee
    June 17, 2015 at 3:44 pm
    tnx my friend. it works . i need to Adobe AE . I wanted to extrude them in AE.
