Activity Forums Apple Final Cut Pro Legacy Problem With Image Sequence
  • Problem With Image Sequence
    Posted by Nick Avaliani on March 1, 2011 at 2:03 pm
    Dear All, Greetings
    I have 88 minutes movie renderred and ready for DCP. I must make TIFF files. So I am writing image sequence from FCP to 6 TB folder, because whole volume is more than 1 TB
    But my computer gets stuck at about 65 000 of files, it happened two times. It first requires 6 hours to finish but than stucks in the middle of the movie.
    Can you tell me how to fix this.
    Or if I write TIFFs by parts will it work in Easy DCP? cause I know files must be numbered from 0001 to the end, so then how it can continue numbering if I stop at 65 000.tiff so how can I continue from 65001.tiff?
    please if you have experienced this help
    Rafael Amador replied 15 years, 6 months ago 3 Members · 3 Replies
  • Chris Tompkins
    March 1, 2011 at 2:51 pm
    Why not output movie from FCP – current settings. Self contained.
    Then open it in QT and export movie to image sequence?
    OR
    Render it out of AE…
    Chris Tompkins
    Video Atlanta LLC
  • Nick Avaliani
    March 1, 2011 at 3:00 pm
    Looks attractive, can you explain this a bit more precisely
    SO I will export movie from FCP? with export > export quicktime movie <>self contained apple prores 444 2048X1080, 24 FPS
    Then I could not understand how to export this movie to image sequence
    (By the way is this common workflow how DCPs are made for big theatrical movies????)
    thanks
  • Rafael Amador
    March 1, 2011 at 3:19 pm
    [nick avaliani] “SO I will export movie from FCP? with export > export quicktime movie <>self contained apple prores 444 2048X1080, 24 FPS”
    But you have a movie already, no?
    You want to export a TIFF sequence; why do you want to export another movie (Prores 444)?
    Chop the movie and export the sequence in batches.
    rafael
    http://www.nagavideo.com
