Activity Forums Maxon Cinema 4D Problem with Global Illumination and the Grass Feature
  • Problem with Global Illumination and the Grass Feature
    Posted by Dren Robinson on December 13, 2018 at 4:52 am
    I’ve been using Cinema 4D for a month or so now and been using it for a hobby, I’ve self taught myself most of what I know from youtube videos or forum posts but I haven’t found anything concerning the issue I’ve been having with it. Whenever I go to render a scene that has grass and I try to add global illumination with the settings of “Exterior – Physical Sky” and a Physical Sky it always appears white. It might be a simple solution that I’m missing but after all there’s just so much of the program I’m unfamiliar with, can anyone help me?
    Mohsen Amini replied 7 years, 9 months ago 3 Members · 2 Replies
  • Brian Jones
    December 13, 2018 at 5:02 pm
    not seeing that in a quick test with the setup you describe, can you post a scene where it happens?
  • Mohsen Amini
    December 15, 2018 at 10:06 am
    u using standard or physical render? try switching between those
