Activity Forums Boris FX Particle Illusion Problem with frames
  • Problem with frames
    Posted by Rob3459 on September 10, 2005 at 2:31 am
    Hi
    I am new to Particle Illusion I have inported an AVI that has 902 frames but all I get is 644 frames can someone please tell me why as I have looked at the help and can’t find anything
    Rob
    Alan Lorence replied 21 years ago 2 Members · 3 Replies
  • Alan Lorence
    September 10, 2005 at 11:05 am
    When you load the AVI, does pIllusion know that it has 902 frames (does “902” show in the layer window)? If so, and you’ve already made sure that the project end frame (set in the playback toolbar) is 902 at least, then I suggest checking the OpenGL page of the pIllusion prefs, and checking the “don’t use texture RAM for bg images” option and see if that helps.
    Alan.
    wondertouch
  • Rob3459
    September 12, 2005 at 12:35 pm
    Thanks Alan for the help so far.
    Yes pIllusion does show “902” frames in the layer window. I did what you suggested in the OpenGL page of the pIllusion prefs,check the “don’t use texture RAM for bg images” option But this did not fix it can you suggest anything else ?
    Rob3459
  • Alan Lorence
    September 12, 2005 at 3:41 pm
    Convert the AVI to an image sequence?
    Alan.
    wondertouch
