Activity › Forums › Web Design (WordPress, Joomla, etc.) › Problem With Form In IE7 Only
  • Abraham Chaffin
    January 30, 2009 at 5:03 am
    Looks like a problem with your dropdown menu.
    https://interstateconstructionllc.com/ActiveContentDropDownWide.js
    It obviously has some glitches in it when it comes to IE and looks like it is creating a layer over your form that is covering up that field. My guess, however, is that a work around would be to move down the form about 10 pixels and you would be out of the way of the layer that is covering the form.
    Put a couple soft breaks above the form…
    Abraham
  • Matt Ganey
    January 30, 2009 at 4:03 pm
    Abraham,
    Thank you! You have no idea how long this has been driving me nuts. I happy it was such an easy fix, I was about to put a different nav menu in just to be done with it.
    You rock, thanks buddy!
