Activity Forums Adobe After Effects Problem with Foam effect in AE CC
  • Problem with Foam effect in AE CC
    Posted by Paul Demontez on December 20, 2013 at 9:11 pm
    Hello,
    I’m having an issue with the foam plugin in AECC.
    What is happening
    https://youtu.be/9Kq9crPgcVg
    As you will see in the video after a few seconds of foam acting how it should it then starts to go crazy and the textures/sprites (whatever) start jumping all over the place erratically . This happens in both RAM preview and render. It continues to happen when I change the settings and textures in foam and when I switch from ‘rendered’ to ‘draft’ so that it is just wireframe ‘bubbles’. I’ve also tried changing the purge rate in the secret menu to many different values. So now I’m handing it over to the internet because I’m stumped and have been wrestling with it for about a day now and I’m pissed off.heh
    Roland R. kahlenberg replied 12 years, 8 months ago 2 Members · 5 Replies
  • Roland R. kahlenberg
    December 20, 2013 at 9:25 pm
    Try Edit>Purge>All Memory & Disk Cache
    Does that help?
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Paul Demontez
    December 20, 2013 at 9:28 pm
    Thanks for the reply, but no it still does the same thing
    December 20, 2013 at 9:32 pm
    Do a restart. If that still fails then try keyframing from scratch.
    My thoughts are that it’s a cache issue.
    Good Luck
    RoRK
  • Paul Demontez
    December 20, 2013 at 9:51 pm
    Yeah I’ve tried that too. I’ve even tried a new project and started a new comp with foam and it still does the same thing
    Even tried reinstalling AE
    December 20, 2013 at 10:31 pm
    Post your AEP here for someone else to take a look at it.
    File a bug – https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform if the problem persists.
    You may also want to use another particle generator as what you’re doing really doesn’t require Foam.
    HTH
    RoRK
