Activity Forums Apple Final Cut Pro Legacy Problem with FCP5 on sending footage out to print to tape
  • Problem with FCP5 on sending footage out to print to tape
    Posted by Alieninnovation on July 14, 2006 at 11:00 pm
    When I captured footage from the analog inputs of the blackmagic card I use blackmagic PAL 4:2:2 uncompressed mode for capture but when I try to output through edit to tape option it says sequence setting doesn’t match and it aborts.
    So what is wrong with sequence setting? should it be CCIR PAL 4:3 or DV 5:4 in setting?
    Howie Chin replied 20 years, 1 month ago 2 Members · 1 Reply
  • Howie Chin
    July 15, 2006 at 9:41 am
    I’m not so sure about the video that u captured matches the sequence…
    if you pulled the footage you captured into the sequence, and it doesnt require render that means the sequence matches the footage…
    Usually in my sequence is DV 5:4..when i put ccir 4:3, it distorts…and could it be anamorphic 16:9 is on?
    good luck
    [howie]
