Activity Forums Adobe After Effects Problem with Element 3D
  • Problem with Element 3D
    Posted by Mehdi Hb on June 7, 2016 at 7:04 pm
    Hey , i have a problem whe im using element 3D in after effect cc
    the problem is that when a select a 3D object into the scene setup the grid is automaticly attached to this 3D object and whene im trying to move it the grid move with it and i cannot scale it
    please help me
    sorry btw for my bad english be cause im morrocan
    Hanna Dean replied 10 years, 2 months ago 3 Members · 16 Replies
  • 16 Replies
  • Kalleheikki Kannisto
    June 8, 2016 at 5:23 pm
    I suspect you don’t have the scale tool selected. It is the fifth tool from the left with a small square inside and a bigger square.
  • Mehdi Hb
    June 8, 2016 at 7:45 pm
    no , ido click on the scale tool but when i click on it and i try to scale it , the object stays as he was
  • Mehdi Hb
    June 8, 2016 at 10:55 pm
    and when i click on a 3D object it make this :
    https://postimg.org/image/h333m9y6j/
  • Hanna Dean
    June 9, 2016 at 12:03 am
    element 3d depends on minimum gpu card, check your graphics driver.
    you said you tried the scale but it dont scale remains as it is well , close it update gpu driver and try again, because each time u move object , resize the gpu is doing the work not the cpu , since its not updating with your scale the gpu is not working on that maybe.
  • Mehdi Hb
    June 9, 2016 at 10:47 am
    i will try i explain all in this video
    https://www.youtube.com/watch?v=eGwNCQ-i3jw&feature=youtu.be
  • Hanna Dean
    June 9, 2016 at 3:22 pm
    Your using internal Graphics card if i am right.
    get a seperate gpu borrow from friend try it.
  • Hanna Dean
    June 9, 2016 at 3:24 pm
    on your video on the top right corner look close
    on element 3d it shows
    0 Mb Graphics memory GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
    your using built in internal graphics my friend you need a seperate graphics card.
  • Hanna Dean
    June 9, 2016 at 3:28 pm
  • Hanna Dean
    June 9, 2016 at 3:29 pm
  • Mehdi Hb
    June 9, 2016 at 7:20 pm
    oh ! well , i have 2 graphic cards
    -Intel
    -AMD radeons
    i may used with AMD but i have some problem with OPEN GL so i unstall the AMD Driver and then it cause me this problem
    i will redownload it now but i will have some problems with Open GL and i dont know how to fix it
