Activity › Forums › Adobe After Effects › Problem with Element 3D
Hanna Dean
June 9, 2016 at 8:06 pmwell u need decent gpu , and to make sure its working on element 3d look on top right were it says video memory ram , that has to be read by element 3d.
as i have shown in my video look on top right my video memory ram , am not using internal graphics , i use seperate gpu.
so you do same , depending on your graphics card do research online ,get the drivers for it what is the model of it.
get that fix then your element 3d wil work
Mehdi Hb
June 9, 2016 at 11:53 pmOh ! i solved the problem by downloading the AMD graphic gard driver but i still have en top right 0 memorie
Mehdi Hb
June 9, 2016 at 11:55 pmthank you so much for you’r help my freind
you really helped me a lot -
Hanna Dean
June 10, 2016 at 12:08 am0 video ram
my friend you have not done what i told you.read my top post , you need a new or second hand graphics card , a shitty internal graphics will not do the job the closest you get is the picture to load or maybe few frames , when it comes to adding effects your will will be on fire.
i assume you dont know what ( new gpu ) or new graphics card mean
look at picture
https://images-na.ssl-images-amazon.com/images/I/81sw0cdn9uL._SL1500_.jpg
https://i.ytimg.com/vi/YbGo335w5gw/maxresdefault.jpgthe graphics that is stuck on your motherboard is shitt full stop.
u need a graphics card ebay it , then you will se performance and no laggs , no fuzzy texture, no speed problems.
Thats the end of my reply and wil not reply no more sorry , if you need help just read from the very top post to bottom and understand good thanks.
