Activity › Forums › Sony Cameras › Problem with editing XDCAM footage in FCP
  • Problem with editing XDCAM footage in FCP
    Posted by Joelle Schon on May 7, 2009 at 9:24 pm
    I am attempting to edit my first project shot with a Sony PDW 700 camera. I downloaded the software and was successfully able to transfer the footage to an external hard drive. The footage appears as clips in the browser and I can play the clips in the viewer with no problem but when I try to move a clip into a sequence, it shows up unrendered. The media is fine because I sent some clips to another editor and he was able to work with it no problem. We were running identical versions of FCP (6.0.5) and Quicktime (7.6)and I used the identical setup. What am I missing?
    Craig Seeman replied 17 years, 4 months ago 2 Members · 11 Replies
  • 11 Replies
  • Craig Seeman
    May 7, 2009 at 9:34 pm
    [Joelle Schon] “when I try to move a clip into a sequence, it shows up unrendered.”
    and when you try to move it in do you get a popup message to match your sequence settings to the source media. You should in FCP 6.0.5 if it doesn’t match.
    You should select the Easy Setup for the XDCAM HD422 at whatever you shot at with the camera (assuming you shot XDCAM HD422 mode).
  • Joelle Schon
    May 8, 2009 at 6:36 pm
    Yes, I get that dialogue box but it still shows up in the sequence with the red render line above it. I used the easy set up that matches exactly the media and I still get the same results. Maybe I haven’t downloaded all the software I needed to? I downloaded XDCAM Transfer 2.9 and SxS Device Driver. Is there anything else I need?
    Thank you for your advice.
  • Craig Seeman
    May 8, 2009 at 6:50 pm
    In Final Cut Pro, look at a clips Item Properties in the browser and post what it says.
  • Joelle Schon
    May 9, 2009 at 5:50 pm
    Yes, I did that but I still get the red render line. I have noticed that the seqence preset switches to “XDCAM HD 1080i 60 VBR at 18-35 Mb/s” although the clips are “XDCAM 422 1080i 60 VBR 50 Mb/s.” There is no exact match in the sequence presets that I can find. There is an “XDCAM HD422 1080i 60 CBR” but when I try that, I get the dialogue box again saying “For best results sequence and clip should match” and when I click OK, the sequence preset switches back to “XDCAM HD 1080i 60 VBR” again. Very frustrating! Could it have anything to do with the fact that I still have OS ver. 10.4.11? Or am using an iMac G5? Is there anyway to add sequence presets?
    Thanks so much for your help.
  • Craig Seeman
    May 9, 2009 at 10:02 pm
    [Joelle Schon] “”XDCAM 422 1080i 60 VBR 50 Mb/s.” “
    Are you sure? Can you take a screen shot of FCP clip item Properties and upload a screen shot using the Image Upload icon (third from right in icon bar above your reply type window)?
    [Joelle Schon] “”XDCAM HD422 1080i 60 CBR””
    That’s what it should be as far as I know. It’s a XDCAM HD 422 50mbps is a CBR, not a VBR codec.
  • Joelle Schon
    May 11, 2009 at 1:29 pm
    Dear Craig:
    Here are frame grabs of my Browser, easy setup and sequence preset. If I try to set them to CBR, I get the dialogue box again saying “For best results, sequence and clips must match etc.” Hope this tells you something.
    Thanks again.
  • Joelle Schon
    May 11, 2009 at 3:59 pm
    Sorry. I hadn’t finished uploading the images. Here they are. Now I am no longer getting the dialogue box when everything is set to CBR but I still get the render line in the sequence. https://i1.creativecow.net/u/138095/sm/browser.jpghttps://i1.creativecow.net/u/138095/sm/sequencepresetcopy.jpghttps://i1.creativecow.net/u/138095/sm/easysetupcopy.jpg
  • Joelle Schon
    May 11, 2009 at 4:01 pm
    I am going to do them 1 at a time.
    Joelle Schon
    May 11, 2009 at 4:04 pm
    Joelle Schon
    May 14, 2009 at 10:20 pm
Dear Craig:
Thanks for all your input. I finally re-installed FCP and the problem disappeared. It now works perfectly.
