Activity Forums Apple Final Cut Pro Legacy Problem with DV Output
  • Problem with DV Output
    Posted by Mark Maness on December 17, 2007 at 10:11 pm
    Ok…. I know….
    Don’t crucify me…. I’ve had a rough day and its not getting any easier.
    I have a program that I have had to downconvert to DV (yeah, I know….) and output to DV (again, I know…). I’ve setup FCP to a DV sequence using all of the defaults, set me deck up properly (HVR-M10U), and… nothing.
    Now… I did it a while ago but not lately. Can someone help?! My head is hurting!
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
    Caspar Stracke replied 17 years ago 3 Members · 3 Replies
  • Jeremy Garchow
    December 17, 2007 at 11:41 pm
    is your deck in HDV mode instead of dv?
  • Mark Maness
    December 18, 2007 at 2:02 pm
    No…. I did check that. I went through and changed everything to DV mode.
    Wayne Carey
    Schazam Productions
  • Caspar Stracke
    September 13, 2009 at 6:53 pm
    Hey Wayne,
    sorry to contact you 2 years later on a post on HDV deck problems.
    I assumer in 23 years you figured it out , right 😉
    I am right in the middle of this ugly problem, finally found the AV devices tap get an output..but in 4:3 format.
    (cropped) even if all possible settings are on 1080 60i….great… any clue?
    Much thanks in any case,
    Caspar
