problem with DV avi larger than 2GB
Hello
I’m working with Premiere CS3, SD PAL footage, captured through firewire and WinDV, as DV avi Type 2. The problem is, when I play the timeline, every single clip that is larger than 2GB has video issues (it stops playing) but the audio is ok. Meantime, all the captured clips are playing smoothly under Windows, don’t care which player I use (MediaPlayer, VLC and so on). If I convert the longer clips to QuickTime movies, and I reimport them in Premiere, everything goes like a charm. Since i don’t want to spend a lot of time for converting, is anybody here who had the same problem and found a way to bypass it? Thanks for all your replies in advance.
(Intel Q6600, 4GB RAM, nVidia 8800GTS, 3 x WD 320GB, Vista x86)
