Activity Forums Apple Final Cut Pro Legacy problem with down converting HDV to DV at 24f
  • problem with down converting HDV to DV at 24f
    Posted by Josh Greytak on October 18, 2008 at 7:23 pm
    Hi, so to start I recently purchased the Canon XH A1 and just started working with it’s HDV power. Recently I agreed to to a recording for a friend and now need to make copies of the work. I shot in HDV at 24f, and now I want to take advantage of the in camera down conversion. Problem is I can’t seem to find a way to retain both 24f and the correct aspect ratio. In easy setup I can only find DV NTSC 48 kHz(23.98) or DV NTSC 48 kHz Anamorphic. for both time line and capturing preset. This might sound stupid but could I just mix and match settings?
    Josh Greytak replied 17 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
