Activity › Forums › Adobe After Effects › Problem with De:Flicker High Speed
  • Problem with De:Flicker High Speed
    Posted by Ryan Kavanagh on July 16, 2014 at 8:08 am
    Hi guys,
    Just wondering if any of you have experienced this before? Basically, De:Flicker does a fantastic job on eliminating the flicker on the phone screen, however it has also introduced a “ghost” effect. Is there any way of getting rid of this?
    Thank you,
    Ryan
    Pierre Jasmin replied 12 years, 2 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    July 16, 2014 at 5:10 pm
    Two things to try:
    1) Set the Max Change to a low value like 10%
    2) Play with Refine mode
    (use the Refine Visualize checkbox to set the Refine Threshold so only the bad pixels in the phone are red)
    Pierre
