Activity › Forums › VEGAS Pro › Problem with compositing modes clashing
  • Problem with compositing modes clashing
    Posted by Daryl Brown on June 4, 2009 at 8:05 am
    Situation: For the intro to my video I have text effects that use the compositing mode “burn”. I have the 3 tracks dedicated to this text effect below all the other tracks because if the tracks with the burn mode on it is on top it will affect the whole video. I want to add a text effect using a different compositing mode at the end of the video.
    Problem: When I make 3 new tracks and try to add a different text effect to the end of the video it gets effected by the “burn mode” track. When I put these 3 new tracks above the “burn mode” track then the “overlay mode” track with the new 3 messed up my intro text effect.
    Question: Is there a way to make a certain track or clip ignore a compositing mode from above?
    – or –
    Is there a way to limit the compositing mode to only a certain clip on the track?
    I’ve been playing around with the program for a while, but can’t find a solution. Any help would be much appreciated.
    Thank you 😀
    In heaven everything is fine
    John Rofrano replied 17 years, 3 months ago 2 Members · 3 Replies
  • John Rofrano
    June 4, 2009 at 11:52 am
    No, you would have to split your source tracks so that they can have their own compositing. You can also do the compositing in a nested project but that doesn’t solve the issue that some are burn mode and some are overlay.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Daryl Brown
    June 4, 2009 at 9:06 pm
    By splitting my source track, do you mean I can make it so i have side by side source tracks and use different compositing modes?
    If that’s not it, what does it actually do and how do i do it?
    thank you for your help 🙂
  • John Rofrano
    June 6, 2009 at 3:05 am
    I mean split your source and physically move part of it to another track and then parent that new track to other tracks with a different compositing modes. You have unlimited tracks in Vegas.
    ~jr
